FARO As-Built Pipe issue
santoshbaraiya
santoshbaraiya
I'm having a Faro camera for trial purpose. After scanning the system, when I import the point cloud in the plant3d and using As-Built Plant, when I do the pipe run, it makes the pipe. But the issue is after the pipe is generated, I cannot change its length, the pipe its making is having the spec I loaded but I'm not able to edit the pipe as we used to do in a regular pipe in plant3d.
Also, the number of properties of the pipe made in as built is not same as we see in normal pipe made in plant3d.
I'm attaching screenshot for reference.
h_eger
@santoshbaraiya ,
please ask Faro, as we can say little about this from the Plant 3D Forum.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
