Hi all,
My company started using AutoCAD Plant 3D and I need help while creating Isometric drawings because the attached error appear: FAILURE - eInvalidInput
I have created a start Point and Break Points in all "T" and Pipe endings, however do not understand what I am doing wrong...
Can someone help me please???
Solved by h_eger. Go to Solution.
Dear @joanna.gonzalezMJU8Y ,
Unfortunately we cannot help with chaos!
Please delete all start and end points and then try again with the iso creation.
FAILURE - eInvalidInput only says that there are parts in the pipeline that have no or wrong SKEY etc.
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear Eger,
I removed all the start and end points and try to run a Quick ISO and Production ISO and unfortunately is still not working.
I attach the . pcf and the error screenshot.
Could you please help me?
Thank you,
Joanna
all ISO's have run ...
Unfortunately there is probably a bigger problem with your 3D model - there are almost no elements connected.
So I get 60 isos from a PCF file.
Hartmut Eger
Senior Engineer
XING | LinkedIn
