Extracting P&ID data from a drawing without a P3D project
david.manningXME8A
david.manningXME8A
Hello Everyone, I have a P&ID set supplied that are supplied by the client, but they do not have the P3D project. So if we import the drawings into our Plant P&ID project many of the assets are missing.
I would like to be able to export the P&ID classes and other information so that I can create those in a new project and then I hope the assets will import.
Has anyone solved this problem?
I have tried, in AutoCAD,  ATTOUT and it won't let me select the P&ID assets. DATAEXTRACTION does not appear to see this data either.
So far the only way I can see to update the project settings to match the drawings received is to manually look at the attributes in AutoCAD and recreate the fields in the project setup. I'd really prefer to avoid this.
Replies (7)
h_eger
Hi @david.manningXME8A ,
without the original configuration of the Plant 3D P&ID project, it will be a Sisyphean task to find out the setting and rework it.
Yes and data extract does not work with the database of P&ID
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
david.manningXME8A
Hello @h_eger, thank you for the response. It is not the answer I was hoping for but ultimately the one I expected.
I credit your use of "Sisyphean" in your response as appropriate and a joy to read at the same time, even if I did have to look up the entomology to be sure. 😉
h_eger
Hartmut Eger
Senior Engineer
XING | LinkedIn
jabowabo
It is possible to interrogate the cached blob database of a non-project file via the .NET API and dump it to whatever format you want. I'd guess this should provide the data you are looking for. If you want to upload a test file, I can send you a very raw dump of the data.
jabowabo
Proof of concept attached.
david.manningXME8A
Hello @jabowabo, That's exactly what I was hoping to do. thank you for the example file.
I will share that with the project Lead and see where they want to go from there.
Is this something that is relatively easy for us to do for ourselves, or would we need to engage someone to do this for us?
If you could share the steps to reproduce the result that might be helpful to several people, as well as us.
thank you again.
jabowabo
It's done via a .NET custom plugin. If you just have less than a couple of dozen files and this is a one-off, I can do it for you if you send them to me. If you want a long term solution or source code, PM me and we'll talk offline.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
