Extra Instrument tagging called up in Instrument Schedules
ace_guru
ace_guru
Hey Folks,
Just admitting up front that all my experimentation in Plant 3D 2020 is purely based on Trail and Error.
Image below show typical flow meter symbol being used...
My question is, when an instrument schedule is printed how many entries should there be for the flow meter? Currently I've got 5. One for the flow meter and then another 4 for each of the tagging associated with it.
Hope I'm just doing something wrong and there's a simply fix to only show one entry per instrument, cause there's about an extra 3 pages of unnecessary info.
Cheers,
h_eger
Dear @ace_guru ,
No, you are doing everything right.
a pipe connected part of the mechanical flow meter
and 4 x instrumentation marking
Results in 5 parts for the flowmeter in the database - all correct.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
