As reference I used all the information in "De-mystifying AUTOCAD Plant 3D Isometrics" and put to a test one butterfly valve on the pipeline and the error keeps the same.
I changed the SKEY from "VYFL" to "VY??" and the TYPE keeps the same "VALVE".
The other components, flanges, reducers, and pipes keep in default, gaskets are wrong so I changed but the problem keeps on.
The strange part is: if I change the iso style to Check_A2 the isometrics generate without trouble. There's anything more I can do?
Here's the log file from Check_A2:
Iso Creation start time : 30/06/2021 09:01:53
Iso Creation finish time: 30/06/2021 09:02:18
Duration : 00:00:24
Output folder : C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings
1 Isometric(s) successfully created with no error conditions:
C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\PCFs\12-ABR-004-Ac2.pcf
INFO - Loading input: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\PCFs\12-ABR-004-Ac2.pcf'
WARNING - Disconnects were found in model of Line Number '12"-ABR-004-Ac2-1'.
WARNING - Lone components were found in model of Line Number '12"-ABR-004-Ac2-1'.
WARNING - Disconnects were found in model of Line Number '12"-ABR-004-Ac2-2'.
WARNING - Lone components were found in model of Line Number '12"-ABR-004-Ac2-2'.
INFO - Loaded '2' model(s).
INFO - Processing: '12"-ABR-004-Ac2-1'.
WARNING - No break points have been specified.
INFO - Model-split has been skipped.
WARNING - Invalid filter expression: 'Existing = 'false' AND SpoolNumber <> '''.
INFO - Processing: '12"-ABR-004-Ac2-2'.
WARNING - ((207,237042518672,48,8382220376825,64491,772405751),(223,762957481376,378,161778302206,64736,6893029808)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - Failed to fit model 12"-ABR-004-Ac2-2 into canvas with no draw area
WARNING - ((207,237042518651,84,9652831329113,64491,772405751),(223,762957481358,395,034716867082,64723,0745823738)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - ((207,237042518643,43,9993537667724,64491,772405751),(223,762957481355,383,000646573133,64743,5324961161)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - ((207,237042518643,84,9998064729043,64491,772405751),(223,762957481355,395,000193527101,64723,0257589982)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - Renamed output file from '12-ABR-004-Ac2-1.dwg' to '12-ABR-004-Ac2-1 (2).dwg'.
INFO - Generated drawing: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings\12-ABR-004-Ac2-1 (2).dwg'.
WARNING - Renamed output file from '12-ABR-004-Ac2-2.dwg' to '12-ABR-004-Ac2-2 (2).dwg'.
INFO - Generated drawing: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings\12-ABR-004-Ac2-2 (2).dwg'.
WARNING - No tables are configured to be exported.
