ERROR TO CREATE PROD ISO/QUICK ISO
Gregote
Message 1 of 8
Gregote
Good morning everybody, i need some help, when i generate production iso of a personalized iso style my plant 3D gives me the following error:
Iso Creation start time : 29/06/2021 10:33:17
Iso Creation finish time: 29/06/2021 10:33:22
Duration : 00:00:05
Output folder : C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\QuickIsos\Drawings
1 Isometric(s) were not able to be created:
C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\PCFs\UserDefinedLine.pcf
INFO - Loading input: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\PCFs\UserDefinedLine.pcf'
INFO - Loaded '1' model(s).
INFO - Processing: 'UserDefinedLine'.
WARNING - No break points have been specified.
INFO - Model-split has been skipped.
WARNING - Invalid filter expression: 'Existing = 'false' AND SpoolNumber <> '''.
FAILURE - Já foi adicionado um item com a mesma chave.
Someone can help me?
Replies (7)
Message 2 of 8
George.Endrulat
Play with the status on the line, try marking it as new/existing/etc.  Assign it a line number, it looks like you may have it set to generate spools, how are you assigning spool numbers?
George
If my post offers a solution, please click "Accept as Solution"
Message 3 of 8
Gregote
I set up my line number tag, but the error keeps showing.  Follow the log:
Iso Creation start time : 29/06/2021 17:32:52
Iso Creation finish time: 29/06/2021 17:33:15
Duration : 00:00:22
Output folder : C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\ProdIsos\Drawings
C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\PCFs\28-ABR-003-Ac2.pcf
INFO - Loading input: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\PADRÃO A3 P-0169\PCFs\28-ABR-003-Ac2.pcf'
INFO - Processing: '28"-ABR-003-Ac2'.
WARNING - Resize defined that model 28-ABR-003-Ac2 may need splitting
If I try to use an existing iso style like Check A2 it works, but if I use my personal iso style it crashes in an error.
Thanks for the help,
Message 4 of 8
h_eger
Dear @Gregote ,
You have a wrong or duplicate SKEY in your pipeline that you want to generate for the ISO
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Message 5 of 8
Gregote
As reference I used all the information in "De-mystifying AUTOCAD Plant 3D Isometrics" and put to a test one butterfly valve on the pipeline and the error keeps the same.
I changed the SKEY from "VYFL" to "VY??"  and the TYPE keeps the same "VALVE".
The other components, flanges, reducers, and pipes keep in default, gaskets are wrong so I changed but the problem keeps on.
The strange part is: if I change the iso style to Check_A2 the isometrics generate without trouble. There's anything more I can do?
Here's the log file from Check_A2:
Iso Creation start time : 30/06/2021 09:01:53
Iso Creation finish time: 30/06/2021 09:02:18
Duration : 00:00:24
Output folder : C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings
1 Isometric(s) successfully created with no error conditions:
C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\PCFs\12-ABR-004-Ac2.pcf
INFO - Loading input: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\PCFs\12-ABR-004-Ac2.pcf'
WARNING - Disconnects were found in model of Line Number '12"-ABR-004-Ac2-1'.
WARNING - Lone components were found in model of Line Number '12"-ABR-004-Ac2-1'.
WARNING - Disconnects were found in model of Line Number '12"-ABR-004-Ac2-2'.
WARNING - Lone components were found in model of Line Number '12"-ABR-004-Ac2-2'.
INFO - Loaded '2' model(s).
INFO - Processing: '12"-ABR-004-Ac2-1'.
INFO - Processing: '12"-ABR-004-Ac2-2'.
WARNING - ((207,237042518672,48,8382220376825,64491,772405751),(223,762957481376,378,161778302206,64736,6893029808)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - Failed to fit model 12"-ABR-004-Ac2-2 into canvas with no draw area
WARNING - ((207,237042518651,84,9652831329113,64491,772405751),(223,762957481358,395,034716867082,64723,0745823738)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - ((207,237042518643,43,9993537667724,64491,772405751),(223,762957481355,383,000646573133,64743,5324961161)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - ((207,237042518643,84,9998064729043,64491,772405751),(223,762957481355,395,000193527101,64723,0257589982)) Overlaps no draw area <(148,32,000000339908),257,52,999999660092>
WARNING - Renamed output file from '12-ABR-004-Ac2-1.dwg' to '12-ABR-004-Ac2-1 (2).dwg'.
INFO - Generated drawing: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings\12-ABR-004-Ac2-1 (2).dwg'.
WARNING - Renamed output file from '12-ABR-004-Ac2-2.dwg' to '12-ABR-004-Ac2-2 (2).dwg'.
INFO - Generated drawing: 'C:\Users\tecwater\Desktop\GUILHERME\P-0169\P-0169 - ETA CUIABA\Isometric\Check_A2\ProdIsos\Drawings\12-ABR-004-Ac2-2 (2).dwg'.
WARNING - No tables are configured to be exported.
Message 6 of 8
Gregote
I figure out something, i try to change my iso.dwt from Check_A2 to the one I use in my personal and the errors beginning to happen in Check_A2 but I'm not figuring out what's wrong.
Message 7 of 8
jabowabo
Can you confirm that your title block is named exactly "Title Block"?
Message 8 of 8
Gregote
Yes it is, follow the image:
