AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Error on routing pipe from nozzle
20 REPLIES 20
Message 1 of 21
2233 Views, 20 Replies
I have created a new nozzle in the catalogue with end type 'FL'.
i have then converted a 3d model into a piece of equipment. When i add a nozzle onto it, i select my new nozzle which i just created. This works fine.
But, when i click on the + to route pipe from the nozzle, i get the attached error message.
Does anyone know why this is?
20 REPLIES 20
Message 21 of 21
jabpascua
in reply to: Attila.Vallyon
hello, i have the same problem regarding the routing of pipe from nozzle that is attached in the cylinder tank, it says error/
The size of nozzle is 4 inch and i want to route a 6 inch pipeline, via reducer / flange, but when i try to attach, it says error/ mismatch/ mix autoflanged error? please hhelp
”Boost
