AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
enlarge a tank
2 REPLIES 2
476 Views, 2 Replies
enlarge a tank
I have a class/symbol for a tank and have it set to scale on insert (XY independent), but once it is inserted, I cannot change it size anymore. is there a way to make the tank higher, bigger,...? Or do i need to delete the existing tank and insert a new one? It seems that the geometry properties of the symbol are not available anymore.
2 REPLIES 2
Dadspackard
@Anonymous,
Select the block, right click and the select Edit P&ID Objects Block.
Scale the block then select Save Changes and Exit Block Editor.
Hope this helps
Tom
aka, Dadspackard, Packin31
in reply to: Dadspackard
Found it. You have to customize the toolpallette and check the scale fields.
