When I generate iso drawing overall dimension length of the pipe is not working. how to solve this ?
Have a look at the project setup > iso configuration > Themes. You will have to enable the "End-to-End" checkbox
(I am using German version of Plant 3D). If you want to have more specific end-to-end dimensions you can activate them in the table below.
Live long and prosper \\//_
Steffen
Steffen
Thanks for your reply , I checked that but it is always enabled.
That says it is set for the default theme (upper right corner) Can you check if it is also set for the small-bore theme?
Thanks for your reply , I checked the small bore section too it is also enabled.
there is another setting to be checked:
It seems that this three checkboxes in the table "Default" unter "Settings" control wether one of these dimension types will generally be used or not, regardless if they are enabled or not in the corresponding settings tab.
