Enable Pipe Support parameter in Data Manager/Export to excel
nuwul
nuwul
Hi.
Is there a way to add pipe support parameter in Data Manager column? Or maybe export this to excel? We only want those parameter for pipe supports that have been used in P3D project only.
I found a way to extract parameter from the pipesupport.pcat using SQL, but this only extracted what we have in the catalog:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/export-custom-pipe-support-dimensional-propert...
h_eger
@nuwul ,
no, the support parameters are not written to the piping.dcf database, so they cannot be exported
This topic has been discussed here in the forum several times, just do a search
I'm not sure if anyone has already programmed an interface for this.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
DVaquand
Hello @nuwul
See topic
https://forums.autodesk.com/t5/autocad-plant-3d-forum/extracting-bom-of-parametric-pipe-support/m-p/...
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
FelixPhan
