Elbow rotated in isometric and lost proper connection
hamid.TCAD
hamid.TCAD
When I create an elbow rolled, the elbow will be rotated in isometric and lost the connection making the isometric completely useless. I am not sure if there is problem in my model or any setting, but I tried different way of modeling. This happens also when I model it even without rolled elbow and just to select a direction not aligned with X or Y axis for the pipe, in this example for horizontal pipe which is not aligned with X Y axis. I appreciate anyone can help.
Replies (7)
hamid.TCAD
Anyone has idea about this issue?
Mj_Dan
@hamid.TCAD check the coordinates of your model, they must be very far from the origin (0,0). Also, try to model your plant using the WCS.
To resolve this, move your model closer to 0,0. Now, to get the accurate coordinates in your isometrics, go to project setup, Iso Style Default Setting to apply the offset value to your new coordinates
This post I made on the same issue might help Isometric Issues: Elbow Disconnecting
hamid.TCAD
Thank you Mj_Dan,
That resolved the issue completely.
hamid.TCAD
Now I see all connections in the model gone. I have to select one by one and run "Connected to Adjacent". They are not huge numbers, but for some of them, isometrics have been created and issued to the client that makes me a bit concerned. Is there any way that we can keep all parts connected when we move them?
chris.perryYFTJY
The solution provided here, although effective in its own way, I don't think reflects the reality of the reason many projects are oriented significant distances from the origin. We have several mining customers that have sites spanning distances of dozens of kilometers, each with 3D model turn-over requirements that drive us to model in coordination with each customers defined plant coordinate system, which often has a singular origin located at a convenient UTM intersection. Generally this doesn't usually cause many issues. In fact, we have a current project where we've integrated customer supplied Autocad and Navisworks models, inserted our own laser scan data using Recap, incorporated piping, structural, electrical and equipment models all together, all centered around a point over 50km from the origin, with project units in millimeters. In this entire project, the only issue we've detected as a result of this offset from origin is the rolled elbow that can't calculate its three points correctly (even a 16" elbow, so we're not talking about 1/4" tubing here where the coordinates are that much closer together), resulting in a disconnected looking isometric. Perhaps Autodesk can have someone take another look at this issue to see if the isometric functions for displaying these elbows can be revisited to accommodate users requirements to meet their customers needs. Simply offsetting the plant opens an entire other can of worms for which I don't think we have much of an appetite.
Fahad_Ghoerobi
I have the same issue.
Is there any update regarding this case?
jesse.wolfe5MVES
Biggest issue is moving the piping models to large real world coordinates in the first place.  That's where the isometric errors and disconnects become a major issue.  The intended workflow is to model using site/project coordinates with a project base point set as the 0,0 point per site.  Best practice is to use a survey point on or near the SW corner of the site so all Northings and Eastings will be positive numbers.  Project/site North is also recommended to minimize skewed piping on isometrics.
Then, as @Mj_Dan mentioned in his post, modify your iso and ortho setup and define coordinate and rotational offsets so that the coordinates displayed on drawings can be real world or SP coordinates if needed.  You also build master reference files where you XREF in individual models and apply the same offset/rotation to the XREFs so that models will be displayed in the real world location for drawing backgrounds and Navisworks.  In some cases you need to create a Civil XREF that is also moved down to site/plant coordinates and rotated to site/plant north for that purpose as well.  It's a bit cumbersome but it avoids these issues of disconnects/iso errors and is the only way to make it all work.
Ortho Coordinate and Rotational Offset
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
