Editing line spacing in a table cell
Aldred
Message 1 of 9
Aldred
When you create multitext you are able to adjust the line spacing say from 1 to 1.5 or 2.
If I create a table and create multitext in the cells the Line Spacing is greyed out and I cannot edit this.
Is it possible that I can change the line spacing for multitext in the table cells?  Is it a setting somewhere?  I need it to be 1.5.
Aldred
Replies (8)
Message 2 of 9
pendean
Community Legend
Community Legend
Message 3 of 9
Aldred
Hi Dean,
Thank you for that.  The text being generated is being automatically created through AutoCAD PLant 3D iso's.  So it will not be user input which I see this being useful.
So do you know if there is a way to get the line spacing active as in the original post.  Not having to type in that "code".
Aldred
Message 4 of 9
Victoria.Studley
Hi @Aldred,
Thank you for posting your question.
The technical solution that @pendean linked to is the only way I know of to accomplish what you're trying to do in core AutoCAD. Are you working directly in Plant 3D though?
If you are, I can move this topic over to the Plant 3D forum for you, where other Plant 3D users might be able to tell you whether or not there's a way around this within Plant 3D.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Message 5 of 9
Aldred
Yes.  I am working directly in AutoCAD Plant 3D.
Aldred
This e-mail message is intended solely for the use of the addressee and may contain legally privileged and confidential information. If you are not the intended recipient or his/her representative, please be advised that any dissemination, distribution, copying, or the use of this message or its attachments is strictly prohibited under law. If you have received this message in error, please notify the sender immediately and please delete this message and all attachments from your computer. All quotes are provided in good faith and subject to change without notice, and further subject to Micrographics terms and conditions, which are available upon request and can be found at www.mgfx.co.za/support/micrographics-terms-and-conditions/. Any information passed along in good faith from sub-consultants or advisors beyond the control of Micrographics is strictly to provide the addressee with an indication of the sub-consultants expertise and/or advice and Micrographics may not be held responsible for any commitments made that fall outside of its core function as an Autodesk Reseller. Should you have any doubt as to the content of this email, please immediately refer it to Micrographics at [email protected].
Message 6 of 9
Victoria.Studley
Hi @Aldred,
Thank you for confirming that. I've moved your topic to the AutoCAD Plant 3D forum, where other Plant 3D users will see it and be able to provide some guidance as to whether or not it is possible to edit the line spacing in a table in Plant 3D as you've described.
Victoria Studley
Message 7 of 9
martinTstewart_Adsk
Autodesk Support
Autodesk Support
This AKN article may help: How to adjust the line spacing in the table cell with the Autodesk AutoCAD
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Additionally, this would be a good suggestion for the Plant 3D Ideastation: more formatting control of tables.
http://forums.autodesk.com/t5/autocad-plant-3d-p-id/idb-p/48/tab/popular
Martin Stewart
AEC Support Specialist
Message 8 of 9
govinda_parasrampuria
All these links seem to be expired as of June 2023.
Can anyone please point those still seeking the solution to a valid source?
Message 9 of 9
jswisshelm
I would like to second this request.
