Editing a pipe run
Editing a pipe run
sherwinQQ42A
Editing a pipe run
sherwinQQ42A
I have 2017 version of Plant 3d. I am running on Windows 10. I have created a long pipe run and inserted into a point cloud and have found that there is a possible interference so I need to edit a small section of the long pipe run (which has many bends). When I try to edit the elbows that I need to edit, the entire run is selected and I cannot edit anything other than pipe lengths. I need to rotate an elbow 45 degrees and change a 90 degree elbow to a 45. Does anyone have any idea how to make my pipe run editable?
Thank you,
Sherwin
Dadspackard
@sherwinQQ42A,
Can you share some screen shots of your pipe run?
Tom
aka, Dadspackard, Packin31
h_eger
Dear @sherwinQQ42A,
i think with CTRL + H your pipelines should be editable in the items
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
sherwinQQ42A
I found the solution. Selecting the pipe, then clicking "unlock connected parts" allowed me to delete the parts in the middle without losing the whole run. To prevent this, I should have not had the Pipe Bends feature turned on when I made the pipe run.
