Dear All,
kindly let me know if there is any way to Edit Service value Or
how to map the Service Description into ISOS.
Rafi.
Plant 3D basic training part 1
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
as @h_eger said: this should be given in your basic plant training. Plant 3D is not a simple program that can be treated as such. Training is a minimal requirement. These forums cannot be a sufficient replacement for basic training. Contact your reseller to see if they can offer training, or use online resources such as Linkedin Learning.
That being said: go to project setup: (PipeLineGroup Service for P&ID) (P3D Line Group Service for P3D)
By using these options I can only Edit Descriptions not Service Value.
My question is how to "Edit Service Value" without delete or Add option.
Any possibility ?
Hello @rafimh2022
No by default
Contrary to the description, to modify the value of a list you must delete the line and recreate it with the new value
== French ==
Non par défaut
Contrairement à la description, pour modifier la valeur d'une liste il faut supprimer la ligne et la recréer avec la nouvelle valeur.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
With the auxalie Plant Express Tools you can export the Selectenlist Service to CSV and edit and import it again.
Hartmut Eger
Senior Engineer
XING | LinkedIn
And why is it important that you do not use the add option? If you want to change the Value and keep the description the same, create a new row with the new value and the old description and delete the original row.
It will be a major task as we already assigned all Service values for all piping and we have more that 10 3d files.
while mapping service in ISOS Title block, only the value is appearing not description but I need to show the description as well.
If the task of changing the service value is too big for you, you can also use the LDT list to get the information on the Iso.
https://www.youtube.com/watch?v=nCV4cioLDdE
Hartmut Eger
Senior Engineer
XING | LinkedIn
