I created a dynamic block with multiple size pipe supports.
After placing the dynamic block on a pipe, I select the correct size support.
I then convert the dynamic block to a plant 3d support.
When generating Ortho views, all supports within the dynamic block display, instead of the one that is selected in my base plan.
I assume this will happen whether or not the dynamic block is a support, meaning this is an issue with the way Ortho's process dynamic blocks.
Autodesk, How can this be resolved:
Solved by PeterQuinn. Go to Solution.
There was a bug about this. I think we fixed it in 2015 Ext 1.
Has this become broken again in 2016???, dynamic 3d block with differeing visablity states shows all states when orthoed
