AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
distance between pipe and wall
3 REPLIES 3
wchomka
445 Views, 3 Replies
I was create pipe and  now I would like to change distance between pipe and wall , haw I can do that.
Best regrads
3 REPLIES 3
Garrett.Brothers
in reply to: wchomka
Hello!
Your best bet is to use the MOVE PIPE grip.  After selecting a pipe, there are three squares you can select, circled in the screenshot below.
Selecting any of these begins the MOVE PART command.  This will let you move the pipe.  You can move it to the wall, then move it whatever distance it's supposed to be.  There are more elegant ways to do this in one command, but this is a simple way to do it.
Your question is pretty basic.  I would recommend looking around at the AutoDesk-produced resources or even YouTube tutorials to learn the essentials of Plant.  Posting questions like this to the forums isn't bad, but you're more likely to get an answer if you try to find it yourself.
wchomka
in reply to: Garrett.Brothers
Hello
Thanks for reply, but I know thise option , Ilooking more simple solutions..
Best Regards
jabowabo
@wchomka wrote:
Hello
Best Regards
If that's not simple enough, you may be using the wrong software.
Technology Administrators
AutoCAD Beta
