AutoCAD Plant 3D Forum
disconnection marker tolerance
4 REPLIES 4
jw7018
372 Views, 4 Replies
Can you adjust the disconnection marker tolerance?
I have a go-by that has random components miss-aligned (like a in-line tee that is 0.0011" below the pipe run.  The problem is that the entire DWG is routed in this fashion. So I can run ISOs I would like to set the disconnection marker tolerance to a 1/64" (0.0156")   I feel it is at 0.000000000"
I am looking into a XML editor...
4 REPLIES 4
jw7018
in reply to: jw7018
This resolved the issue:
http://www.firstobject.com/dn_editor.htm
jw7018
in reply to: jw7018
So....... the xml editor worked in the model. All the disconnection markers went away and a weld gap is inserted when a component it offset from the pipe run but within a set tolerance.
However ISOs will split each component to it's own page or generate an ISO with a bad view rotated vertical (not 30 degrees) and a chain dimension to the place where the component is off set.
Has anyone found a solution where ISO will generate when a disconnection tolerance is greater than 0.0" ?
dave.wolfe
in reply to: jw7018
Can you post a screenshot of the tolerances you used?
Dave Wolfe
Isaiah 57:15
Tips and Tricks on our blog: ASTI blog
EXPERT ELITE MEMBER
Plant 3D Wish list
jw7018
in reply to: dave.wolfe
I set the disconnection marker tolerance to a 1/64" (0.0156")
This worked in the model and the disconnection marker went away.
Unfortunately the Isos would not produce, which was my original intention.
”Boost
