AutoCAD Plant 3D Forum
Dimensioning between supports and branches
6 REPLIES 6
KSchieck
290 Views, 6 Replies
Hi all,
I've been having this problem and can't seem to find a solution for it.  When I run an iso and it has for example a flanged spool with 2 supports or branches, the iso style will dimension from the right side to the leftmost branch, then again from the left side to the rightmost branch and dimension in between the branches, I just want it to dimension from the right to the left in a string.  I can't find the setting that would change this. See attachments.
6 REPLIES 6
AndyDavisCadline
in reply to: KSchieck
You want to turn off the Locating dimension for Support and add a String dimension for Support.
Remove Locating dimension
Add new String dimension
Making the above change to the oob configuration of CHECK_A2 gives this result:
Andy Davis
Industry Specialist
Cadline Ltd.
KSchieck
I just tried that, gives same results as before
AndyDavisCadline
Which version of Plant 3D are you using?
I seem to recall this was a defect a few versions back.
It works for me in 2025.
Andy Davis
Industry Specialist
Cadline Ltd.
KSchieck
2023
DVaquand
Hello @KSchieck
This is a bug noted on version 2023. It was corrected on versions 2024, 2025.
== French ==
C'est un bug constaté sur la version 2023. Il a été corrigé sur les versions 2024, 2025.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
KSchieck
in reply to: DVaquand
Oh that's great, I've been struggling with this for a year.  Upgraded and it's fine.
Technology Administrators
AutoCAD Beta
