Descriptions and Cut List is missing in Isometrics
Message 1 of 17
Hello, im new at AutoCAD Plant 3D. My problem is when i try to take isometri of my drawings, there is nothing on description tab, also I cant see the cut list on isometri aswell. I attached some photos to clarify my problem.
Thanx in advance.
Replies (16)
Message 2 of 17
Dadspackard
@Anonymous
Need to have the Cut Pieces checked in order for the Cut Piece Table to appear on the Isometric
Tom
aka, Dadspackard, Packin31
Message 3 of 17
@Dadspackard
I have checked that option. I tried to uncheck/check again but it didnt work. Still having a same issue.
Message 4 of 17
Dadspackard
@Anonymous,
Can you share the PCF file with us for testing here?
Tom
Message 5 of 17
@Dadspackard
Yes i can but as i said, im new at this programme so i dont know how to export pcf file. If you can tell me how to do it, i can share 🙂
Message 6 of 17
Dadspackard
@Anonymous,
You should find it in the Projects Iso Style folder that you used to create the isometric.
ex.  C:\Users\dadspackard\Documents\MMETRIC_TEST\Isometric\Final_A2\PCFs
Tom
Message 7 of 17
@Dadspackard
Thanx. I attached zip file.
Message 8 of 17
Dadspackard
@Anonymous,
Thanks for posting the PCF file.
Using a MMETRIC project that I have setup for testing I used the Final_A2 Iso type (OOTB) and was able to generate isometrics from the PCF you attached.
Could you send me the whole ISO Style folder so I can test it here?
Tom
Message 9 of 17
@Dadspackard Well i tried again. Still cant see the cut list and descriptions. I attached isometri files.
Message 10 of 17
Dadspackard
@Anonymous,
Which style do you use from what you posted?
Tom
Message 11 of 17
@Dadspackard
I used Final_A3 firstly but after i tried all of them and didnt work.
Message 12 of 17
Dadspackard
@Anonymous,
Sorry I should of asked you before what version of Plant 3D are you using?
Tom
Message 13 of 17
@Dadspackard  I use latest version but its trial. I want to ask 1 more thing. Whats difference between Final_A2 and Final_A3 ?
Message 14 of 17
Dadspackard
@Anonymous,
Latest version as in 2021?
For it being trail version not sure what features can be used. That be something that Autodesk will need to answer
Ok I tested the Isometric styles A2 AND A3 that you posted in versions 2019 and 2020 and was able to produce the isometrics and the cut list was populated.
The difference between Final_A2 and Final_A3 is the size of the border.
Tom
Message 15 of 17
@Dadspackard
Yes its 2021. I just downloaded it today. When i add "Long Description(Size or Family)", i can see desriptions. I just cant see if its only "Descriptions"
 Thank you so much for helping also
Message 16 of 17
Dadspackard
@Anonymous,
You are most welcome.
I am not sure why it does not want to read it for you.
That field is hard-coded in the table setup dialog box. You can only Check it or Uncheck it.
So I am not sure what property that one reads.
If I had 2021 installed I would be testing it out for you.
This is a work Laptop so we are limited to what we can install.
Have a pleasant evening, weekend and be safe
Tom
Message 17 of 17
Gokhan_Kaya
Hi
This error occurs if the window region option is set to Turkish.
Change region option from Turkish to English (American)
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" ("Accept as Solution") seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ("Kudo") ile ödüllendirin.
Gökhan Kaya
Tehcnical Manager
Autodesk Inventor Certified Professional 2015
LinkedIn
MSI WS 60 i7 Quadro M2000M
