I'm creating P&ID's using SQL. When engineers edit columns in the database, the information doesn't show up in the Data Manager in Plant3D. Items like "Manufacturer", or "Model No." are filled in, completely visible in the SQL, but don't show in the Data Manager. I need this information to generate the reports from Plant3D; how can I make that happen?
Solved by jabowabo. Go to Solution.
Try closing the Project, purging the cache, and reopening.
My understanding is that your local cache should sync up automatically - I'm not certain how reliable this is. There was a blog post a while back showing how to set up a command line switch to automate the purge function if you want to be certain your getting the latest database data.
