CUT PIECE LIST
CUT PIECE LIST
≡ EqVert ≡
CUT PIECE LIST
≡ EqVert ≡
Part of a pipe was lost
Prompt where the piece of a pipe disappears and how to return it into place?
h_eger
Dear @≡ EqVert ≡,
for the cut piece list, the shortest distance between the objects is always calculated.
For this you have the possibility to assign a length of machining to the pipe sections.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
≡ EqVert ≡
But for pipes of different diameter length is calculated
≡ EqVert ≡
Length of cutting isn't calculated only for pipes of equal diameter.
h_eger
Dear @≡ EqVert ≡,
please report this error to Autodesk Support
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dan.Scales
Hi @≡ EqVert ≡,
The issue where stub-in branch pipes that are equal in size to the header do not have the correct cut length in the isometric CUT PIECE LIST has been logged with our development team.
For now, the only workaround is to manually update the table.
Dan
Dan Scales
MKK20
Is this issue (wrong cut length for  stub-in of same size ) fix in 2020 version
