Cut lenght in feet & inches in annotation
MARTINAMEDEO2597
Message 1 of 17
MARTINAMEDEO2597
I'm using 2019 P3D and I'm trying to get an annotation in my ortho view that will show the cut length of a section of pipe in feet and inches. Right now when I set up and annotation for "cut length", it shows as decimal inches. I would like this to be in feet and inches format.
Marty
Replies (16)
Message 2 of 17
CADobi-wan
This can be changed in the ISO defaults under project setup. See screen shots below.
Please "like" and "accept as solution" if this resolves your problem!
Rob (Autodesk AEC Collection 2018, 2019)
Civil Engineering Design Specialist/CAD Manager
www.CADmitment.com
Message 3 of 17
MARTINAMEDEO2597
Rob
Thanks for your reply but I want this feature for my ortho drawings, not the Iso's. What puzzles me is when I scroll over the pipe in my 3D model, I get the cut length in my roll over tool tips in feet and inches. Don't understand why it doesn't work in my ortho annotations?
Marty
Message 4 of 17
CADobi-wan
oops sorry for the misread. When I see cut length annotation I think ISO. Since I cannot replicate this, here is a suggestion.
If you go to project setup; under plant 3D class definitions and find the ortho annotation style you are using. Click on edit block and see what the units are set as. I have noticed in the past that they default to decimal.
www.CADmitment.com
Message 5 of 17
CADobi-wan
Another thing to try is in the same location click the edit annotation and set the properties to inherit object properties and not to use the style property.
www.CADmitment.com
Message 6 of 17
romanzimin
I think the only way is to add ISGEOMETRY=TRUE attribute to CutLength column.
If you can manually edit your db. PnPColumnAttributes table
Message 7 of 17
MARTINAMEDEO2597
Where would I find this to make the change. I'm not too savvy when it comes to making changes to the software.
Marty
Message 8 of 17
romanzimin
Piping.dcf, if SQLite project. You can edit it in any SQLite editor
Message 9 of 17
quentin.contreras
Autodesk Support
Autodesk Support
@MARTINAMEDEO2597  were you able to resolve the information that @romanzimin posted?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 10 of 17
MARTINAMEDEO2597
I have not tried this since I'm not comfortable going in and changing databases. I don't know enough about what has to be done, so I stay away. I guess I'll have to wait until Autodesk makes the revision in a future release. I appreciate Roman for offering a solution, but I won't fool with the DB.
Marty Amedeo
Message 11 of 17
Alex.Pena
Autodesk Support
Autodesk Support
Hi @MARTINAMEDEO2597  ,
I created a video walking through the steps on how to make the edits to the database. I would always recommend making sure to have backups of the database before making any edits. Incorrect changes could cause corruptions with projects. I used the SQLite Expert database editor for the example. Hope this helps.
Video link here
Please hit the "Accept as Solution" button if my post resolves your issue, "Like" if it helped you out, or both.
Alex Pena
Outcome Engineering
Link Name | Link Name | Link Name | Link Name
Message 12 of 17
MARTINAMEDEO2597
I am out of my office until Monday but will be sure to try this when I get back in, and thank you for responding. I will follow up with you after trying this solution.
Marty Amedeo
Message 13 of 17
MARTINAMEDEO2597
Alex
i followed your video and when I came to saving the changes I got an error message and i couldn't save my changes. I'm enclosing a screen shot of the changes in SQLite along with the error message text file that was generated.
Thanks, Marty
Message 14 of 17
Alex.Pena
Autodesk Support
Autodesk Support
@MARTINAMEDEO2597  and I were able to walk through the video with the .dcf file in question and resolve it. The video is the recommended work flow for getting this done. Just please make sure that the line gets assigned a number in the database. This will confirm the attribute has been added to the table.
Alex Pena
Outcome Engineering
Message 15 of 17
dharunkumar.am
This works for me. I have a special condition where I need pipe cut lengths in feet and inches in a metric project. How do I get that?
Message 16 of 17
romanzimin
Where in Ortho view? Will setting Architectural UNITS in the dwg before placing annotation help?
Message 17 of 17
dharunkumar.am
I’m working on a metric project where I need to create a property that shows the pipe cut length in feet and inches, based on our customer's request. The idea is to use ortho annotations to pull the property value for our ortho drawings.
