Good morning all,
I was wondering if any of you have developed their own library of custom P&ID symbols? That can be used in multiple projects. If s, can you please share the steps to be able to use them in all projects? I have created mines, but they reside on the P&ID they are into and I have not find a way to have them available on other projects or even other P&Ids within the same project.
Thank you for you time!
Jaime
Solved by DVaquand. Go to Solution.
Dear @engineeringR8FAX ,
have you ever worked with Project Compare?
https://help.autodesk.com/view/PLNT3D/2023/ENU/?guid=GUID-E5BD2ED6-C7A8-40C9-A167-7A6204587B85
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hello
As @h_eger says, you can use the "Project Comparator" to transpose your P&iD symbols from an existing project to another existing project.
If you need to create a new project, simply check the "Copy parameters from existing project" box and select the "Project.xml" file of the existing project.
This will transfer all data (except DWG P&ID, 3D, Ortho and Iso) from the existing project or template to the new project.
If your tool palette is correctly localized, you'll find all your P&ID symbolism there.
Translated with www.DeepL.com/Translator (free version)
== French ==
Comme le dit @h_eger , vous pouvez utiliser le "Comparateur de projet" pour transposer vos symboles P&iD d'un projet existant à un autre projet existant.
Si vous devez créer un nouveau projet, il vous suffit simplement, lors de sa création, de cochez la case "Copier es paramètres d'un projet existant" et de sélectionner le fichier "Project.xml" du projet existant.
Cela récupèrera toutes les données (sauf les DWG P&ID, 3D, Ortho et Iso) du projet (existant ou gabarit) vers le nouveau projet.
Si votre palette d'outils est correctement localisée, vous y retrouverez toute votre symbolique P&ID.
Cordialement
Dominique VAQUAND
www.dovaq.fr
Si mon message propose une solution, veuillez cliquer sur "Accepter comme solution"
If my post offers a solution, please click "Accept as Solution"
Cette publication vous a-t-elle été utile ? N’hésitez pas à attribuer la mention J’aime à cette publication.
Avez-vous obtenu la réponse à votre question ? Cliquez ensuite sur le bouton ACCEPTER LA SOLUTION.
