Custom Simple BOM table
Ray_K
Ray_K
Hi ALL,
Is it possible to create a custom BOM table layout similar to Simple BOM (separate Fab & Erection Items) but make Instruments and Valves on other group. See screenshot below.
Just need 3 Groups: all Fabrications items, Erection items and Instruments/Valves
I tried modyfing the isoconfig.xml file but no luck.
h_eger
@Ray_K ,
You cannot change this in IsoConfig.xml.
This should be adjusted in Iso.dwt.
Select the BOM once so that it is separated into Fabrications items, Erection items and then add the Valve and Instrument list. It is a bit fiddly but possible
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Ray_K
@h_egerThank you for the input. I will try as you mentioned.
