Custom Python Supports calling other custom scripts
dmckagueN6VZ3
Message 1 of 14
dmckagueN6VZ3
Hello all,
We currently use python scripts for custom supports. I have been trying to find a way to add new 'primitive' shapes that I can use in the scripts. For example, instead of creating 3 BOXES every time I need to make a channel shape, I just want to write a script creating our most used channel sizes, then call that channel script once in the final support script. Is this possible?
I have called OOTB python scripts into my custom support scripts just by including, for example, "from varmain.divsub.cbolt6_001 import CBOLT6_001". But I am not sure how to translate that to use a script from the custom path. I have also tried to add my own compiled custom scripts to the 'variants.zip' folder and then calling them using the same import style but didn't have success. I'm assuming because the activation of the OOTB and custom scripts are different.
If anyone could offer assistance it would be greatly appreciated!
Replies (13)
Message 2 of 14
李榕华|Ronghua.LI
You can refer to the following link:
https://forums.autodesk.com/t5/autocad-plant-3d-forum/python-scripting/m-p/6900759#M26125
李榕华
13489140049@qq.com
Message 3 of 14
rajendra.prajapat
@dmckagueN6VZ3  please use below lines to call the python script from custom script folder.
import os
import sys
sys.path.insert(0, 'C:\AutoCAD Plant 3D 2021 Content\CPak Common\CustomScripts')
from (script name) import *
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Message 4 of 14
dmckagueN6VZ3
Our custom scripts and shared folder are on a network drive. Would it still work the same if I just enter the network path instead of the C:\ drive path or will it have to be stored local?
Message 5 of 14
rajendra.prajapat
@dmckagueN6VZ3 just replace the path and checked.if it will not work then please let me know.
Message 6 of 14
matt.worland
Hello @rajendra.prajapat,
I see you are adding it to the first position, is there a benefit to adding it there instead of appending it to the end?
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
Message 7 of 14
rajendra.prajapat
@matt.worland no benefits , it is just practice.
Message 8 of 14
matt.worland
Thanks, one thing we have noticed is that it can be added multiple times. Be sure to check if it exists before adding:
scriptpath = os.path.normpath(sys.PnP3dNativeContentCustomScriptsPath)
if scriptpath not in sys.path:
  sys.path.append(scriptpath)
Message 9 of 14
dmckagueN6VZ3
Looks to be working from the network path given. I have not added it to a catalog or spec and tested yet but it works when testing the script with (TESTASCRIPT "").
However, I am having another issue now. I can call my secondary script and use it in another, but whenever I try to rotate or translate the object created with the script it will not run. Below is a small snippit of my test code.
def TESTW4(s, N = 0.0, D = 3.50, L = 72.0, ID = 'SPS-W4', **kw):
# Location Parameters
R1 = D / 2.0
# Structural members
s1 = W4x13(s, E = L/2)
s1.rotateX(90)
If I leave out the line "s1.rotateX(90)", it works fine and creates my W4x13 beam from my secondary script. But if I add that line, or a translate or anything else, I get the error "Geometry can not be generated with the given parameters.nil". There are no errors when registering the script though. Is this not possible?
Any suggestions?
Message 10 of 14
plantinfo28
@dmckagueN6VZ3  check the indention error.
Message 11 of 14
rajendra.prajapat
@dmckagueN6VZ3
please use this s1.rotateX(90.0).
Message 12 of 14
phantri.bl
How to creat quickly L or C or H channel without 2 BOX or 3 BOX in python ?
What is the command? if you have experience or you can creat quickly. Pls teach me.
Tks
Message 13 of 14
l_fatych
In the sub-function return the body - I tried and it works.
Example
def W4x13(s, N = 0.0, D = 3.50, L = 72.0, ID = 'SPS-W4', **kw):
       o1=BOX(..........)
       return o1
Message 14 of 14
Fahad_YK
Hi @rajendra.prajapat ,
Do You ever develop custom Python support based on company pipe support standards?
I'm planning to develop a custom Python support based on my company's pipe support standard.
Do You have any advice on how I do it and where to start?
