- Mute
- Permalink
- Report
Hi everyone,
I’m currently developing a custom pipe support for a mixed metric project. I’m using inches ("in") as the LengthUnit in my script.
Then I created a New Support in the SUPPORTS Catalog based on my script,
I imported the Support to the PipeSupportsSpec in my Imperial Project, everything works perfectly. I can modify parameters like stretching without any issues.
However, when I imported the Support to the PipeSupportsSpec in my Mixed Metric Project, I can not alter the parameters. I've set the ComponentDesignation to "Custom".
I've tried to switch the LengthUnit to "mm" and modify all the values in my script to use mm. But when I placed the support it showed so big shape size (seems converted to an inch unit) in the Plant 3D for the first time. I must alter one of the parameters a bit to trigger the correct shape size.
Has anyone else encountered this issue before? If so, how did you handle custom parts for mixed metric projects? Any insights would be greatly appreciated.
Here I attached my script.
Need help from Top Solution Authors:
@h_eger
@Michiel.Valcke
@quan_hm
Thank You Guys..
