Custom pipe support
Custom pipe support
Custom pipe support
I am trying to create custom pipe support in AutoCAD Plant 3D first time. I am using following link for the same.
https://knowledge.autodesk.com/support/autocad-plant-3d/learn-explore/caas/sfdcarticles/sfdcarticles...
I have followed all steps mentioned in the above link. But at the last stage if I click on ‘Save to Catalog’ then it prompts for message “Matching pipe OD should be filled with correct value”.
What is relation of pipe OD in creating supports?
I tried many times. May be I am missing something.
Please suggest solution for this issue or please share any other detail procedure for creating custom support which haves detailed steps.
Thanks.
h_eger
Dear @Anonymous ,
please check the areas marked RED in the Spec Editor
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Dear Sir,
Thanks for the reply.
My screen is different than you.
I have added only one size i.e. 2" because I am doing it first time.
Refer attached snap shot...
h_eger
Dear @Anonymous ,
now my guidelines
Hartmut Eger
Senior Engineer
XING | LinkedIn
Dear Sir,
My problem is resolved. Actually these details was hidden, now it is visible.
Thanks for your replies.
