Custom PID objects revert to original after Project setup has been opened
radi.dimitrov
radi.dimitrov
Hello everybody,
I am not sure if I am missing something here, but when I use the [Convert to P&ID object] command to create a custom symbol in Plant, and then open the project setup, the new symbol reverts to its original from the class definition.
Is it the wrong workflow I am applying or a setting I have overseen..??
Help will be appreciated.
Thanks in advance!
AndyDavisArkance
Convert to P&ID Object will create a single instance of a P&ID symbol for you using the converted geometry.
If you want to add the geometry to your symbol library to use as the default representation of a symbol, you'll need to do that through Project Setup.
Andy
Andy Davis
Industry Specialist
ARKANCE
radi.dimitrov
Hi Andy
Thanks for the answer!
I want to use a single instance symbol in the current project.
When I make the symbol (a simple rectangle f. ex.), I need to assign it to a class that already has a symbol defined.
Then everything is fine until I have to do something else in project setup. When I open project setup the single instance symbol I have created turns to its default class definition symbol.
Is that the normal Plant 3D behavior?
I don't think I have encountered that before.
Regards
AndyDavisArkance
No, definitely not normal behaviour.
What class of symbol are you creating?  If the class has a Symbol List type property defined, like the Normally property for Hand Valves, that may be causing an issue.
Andy
Andy Davis
Industry Specialist
ARKANCE
radi.dimitrov
Hi Andy
Thanks for the prompt answer.
It is a Field PLC I am trying to create. It does not have a Symbol list property in the class definitions.
I tried with some other default instrument classes, and they all do the same.
I think it has something to do with the type and loop number annotation that reside inside the block.
I have previously created an instrument class that does not have annotations, and it does act normally.
(didn't revert to the class symbol)
Thanks for the hint, at least now I can avoid getting into that issue again.
Regards
Radi
