custom orthographic annotation
m_aljweijati
m_aljweijati
Hi all,
I was trying to make special annotation in the ortho drawing to define the elevation for a specified point not the Z (0) of my project, i used this articl :
"How to create an AutoCAD Plant 3D ortho annotation, which shows the relative elevation of a compone...
but the idea is how can i assign the floor elevation?? it didn't work with me any sugesstion ?
Michiel.Valcke
What step didn't work exactly?
In step 1 and 2 you are supposed to make a floor elevation property for all pipe run components. Once you have done that you can set the floor elevation in that property for each piping component.
We are going to need more information.
m_aljweijati
Thansk for you replay,
I did all the steps but i didn't know how to assign the floor elevation value for my pipe, should i added manually in the properties menue?
Michiel.Valcke
Yes,
When you select the pipe component that you wish to annotate, you should see the floor elevation property. Fill that in and you should see your calculated property give you the correct value of the difference between the Z-level and the floor level.
If your calculated property remains blank, try the PLANTREFRESHACQPROPERTY command to refresh acquisition rules and others. If it still remains blank, go over all the steps again one by one.
m_aljweijati
Thank you it was really helpful.
I missed also the refresh part.
appreciat it.
