AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Custom catalog for process air ducts and fittings
2 REPLIES 2
ntzimas
739 Views, 2 Replies
I have no experience with Plant 3D but I want to try it in designing process air networks.
The networks will contain ducts with nominal diameters like Ø560 or Ø630 (mm) and I cannot find an existing catalog that contains those sizes.
Am I missing the correct catalog for ductworks?
Should I build a custom catalog from scratch? Any suggestions on the workflow?
Thank you in advance
2 REPLIES 2
h_eger
in reply to: ntzimas
Dear @ntzimas ,
Plant 3D is intended for process lines according to DIN 0 or ASME dimensions.
Exhaust ducts like those from the manufacturer Jacob are not included as standard and you have to buy or create them yourself.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
ntzimas
in reply to: h_eger
Thank you for your reply.
We don't use only ducts like the ones from Jacob but certainly you show me the right direction.
Nikos
