Custom 3D Block Based Support issue.
popovUS9BY
popovUS9BY
Hello Colleagues,
I tried to create custom point/anchor support using "ConvertSupports", but pivot/connection point far is far away 3D block.
Support is not connected to the pipe and does not appear in iso sketch.
How can I make pivot/connection point where it should be also support to be part of the pipe?
Supports are for CS150 spec pipe diameter of 125/5".
3D block is attached.
Regards
h_eger
@popovUS9BY ,
Please adhere to all rules for creating block-based supports.
1. insertion point of the block = 0,0,0
2. set shaded mode when creating from the block into a support so that it works with the insertion point in Plant 3D.
3. Complete all data in the properties window so that something arrives on the iso
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
popovUS9BY
Hello h.eger,
thanks for reply!
I played a lil bit with coordinate system and third try (red one) became successful!
Support appear also in ISO's BOM - great!
Danke for your support!
