Hello everyone
Im currently using P3D 2024 and i have problem with grating
Outline model:
Shape model:
When I checked the shape model in the ortho, it looks like this
Please help
Solved by Michiel.Valcke. Go to Solution.
Solved by h_eger. Go to Solution.
Unfortunately, such functionality is not supported in Plant 3D Structural.
Use Advance Steel to create such gratings
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
@h_eger
I see, but do you know how did they manage to do this here? I tried it the same shape but the result is the same.
autocad-plant-3d-create-circular-grates
let me put it this way, if a little luck is involved it can work, but it is no guarantee of success.
Hartmut Eger
Senior Engineer
XING | LinkedIn
The problem stems from the circular part of your shape. You can avoid it by using the polygon command (with a lot of sides) when creating your contour. See the below examples. The first is made from two circles, the second is made from two polygons with 40 sides each.
