cursor issues
cursor issues
tbnorris
cursor issues
tbnorris
just upgraded to Plant 3D 2019 and i need to turn off the dimension lines and angles that comes with placing pipes.
please see screen shots below.
Alex.Pena
Autodesk Support
Autodesk Support
Hi @tbnorris,
If you're referring to the red angle in your first picture, you can toggle that off by selecting on the Compass button (Home Tab > Compass Panel).
If you'd like to disable dimension lines, you can toggle off the dynamic input. I have attached an article link that will show how to accomplish this below. Hope this helps.
Article link here
Please hit the Accept as Solution button if my post resolves your issue
Alex Pena
Outcome Engineering
Link Name | Link Name | Link Name | Link Name
tbnorris
Never noticed that switch before.
