Create an orthographic view via the C# API
annh2Q9TB
annh2Q9TB
Dear All!
How can I create an orthographic view via the C# API? I'm trying to use the PnP3dOrthoDrawingsUI.dll, which has a CreateOrthos() function. However, I'm having some problems: I cannot programmatically select the viewport placement points on the drawing using the C# API. Currently, I have to use the mouse to pick the points manually.
public static void CreateOrthoView()
 var doc = Application.DocumentManager.MdiActiveDocument;
 var db = doc.Database;
 var ed = doc.Editor;
 try
   var selectedModels = new StringCollection();
   selectedModels.Add(@"D:\Annh\Plant3D Tool\Plant 3D Project\Test_Project_001\Plant 3D Models\001.dwg");
   string viewName = "FrontView";
   double scale = 0.5;
   double viewportWidth = 250;
   double viewportHeight = 250;
   double viewportDepth = 500.0;
   Commands.ViewType viewType = Commands.ViewType.Front;
   string strViewType = "FrontView";
   Vector3d viewDir = new Vector3d(1, 0, 0);
   Vector3d upVector = new Vector3d(0, 0, 1);
   Point3d lowerLeftPt = new Point3d(0, 0, -250);
   Point3d upperRightPt = new Point3d(500, 500, 250);
   var cubeSolid = new Solid3d();
   cubeSolid.CreateBox(500, 500, 500);
   var orthoView = new PlantOrthoView();
   orthoView.CreateOrthos(
     selectedModels, viewName, scale, viewportWidth, viewportHeight, viewportDepth, viewType,
     strViewType, viewDir, upVector, lowerLeftPt, upperRightPt, cubeSolid);
   catch (Exception ex)
    ed.WriteMessage("\n Error: " + ex.Message);
Thank you very much for your support!
jomar_hipolito
Have you solved your problem?
Logesh_MarimuthuGJ3SM
Hi @annh2Q9TB ,
Did you resolve this issue?
