AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Coustom Line Numbers in Isometrics
3 REPLIES 3
milic.srdjan
726 Views, 3 Replies
Hi to all,
After reading this tutorials
http://www.pdoteam.com/2013/07/complex-line-numbers-in-isometrics/
and
http://www.davetyner.com/2014/01/autocad-plant-3d-how-to-customize-the-line-number-to-match-a-client...
offtopic : many thanks to PDO Team and people from davetyner, I learn a lot from YOU, just keep goin' on
I thought that I start understanding dealing/editing isoconfig.xml, but, but...
In model I have line numbers formated as
FLUID-NUMBERsufix where sufix is a "SMALL LETTER"
e.g. ANV-8a, ANV-8b, LA-10a
but when I start ISOS, for that pipe line, I get good file name (.dwg), but on ISOs I get everything with BIG LETTER (CAPS LOCK)
Look at picture,
Is it possible to keep on ISOs, exactly the same letter size as in model.
3 REPLIES 3
h_eger
in reply to: milic.srdjan
ISOCONFIG.XML
Set: ForceUpcase="false"
Standard is ForceUpcase="true"
Regards
Hartmut
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
milic.srdjan
in reply to: h_eger
Thank You on so fast response...
This is correct solution, KUDO for You...
Do You have idea, for two more things 🙂
1.On Isometric DWG Settings>Annotation
"End connection annotation" window for Connected equipment nozzles
when I add additional text to window
 Connection text:  <Equipment.Tag> <Nozzle.Tag>,
                             <Equipment.ShortDescription>
look @link
http://help.autodesk.com/view/PLNT3D/2015/ENU/?guid=GUID-0BDB5F4F-520B-4F03-A42C-1EAA8AECB539
on ISOs I have two more additional empty lines below "CONNECTED TO" text on ISOs. Why ? (We had that problem sience P3D2012)
2. For a pipe component: Pressure Relief Valve, Spring Loaded with
                                       TYPE=INSTRUMENT-ANGLE,SKEY=RAFL
I add in isoconfig.xml new ComponetScheme
<ComponentScheme Name="Instrument-AngleTag" AnnotationStyle="WipeCircle" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="INSTRUMENT-ANGLE" Fields="TAG" />
to force isometric to show TAG for this type of componet, like for others instrument, but I do not get "bubble with tag in it" 🙂 🙂
e.g. for regular instrument i have similar ComponentSheme
<ComponentScheme Name="InstrumentTag" AnnotationStyle="WipeCircle" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="Always" Filter="Instrument" Fields="TAG" />
and work perfectly
Ideas ?
For empty line below "CONNECTED TO", just put your cursor at the end of the sentence in "Connection prefix" and press "delete" three or four times.
I  solved same issue with this.
Regards
Technology Administrators
AutoCAD Beta
