Copy Specs and change Class one TIME
mohamedali10006
mohamedali10006
I have a whole specs with all components for Class 150, if there is any way to copy the same components but modifing class and then I can change thickness one by one, not to add everything from scratch?
Tomislav.Golubovic
You'll need to copy+paste in the catalog then add that new entry to the spec.
h_eger
@mohamedali10006 ,
technically, you could do this via “Save As...” or via “New - Creating Spec From Existing...”
But modifying all parts afterwards is a lot of work and you create a unique spec that has nothing to do with the catalogs and updates of the spec from the catalog are no longer possible!
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
