I created some master report configuration files in the file destination is under the general option. Is there a way to copy all of these master reports so they will end up in the project directory?
Solved by h_eger. Go to Solution.
Dear @mvanderhulst2 ,
Welcome to the Plant 3D Forum
Can you please define your questions for us so that we can also work.
In this report you write about reports but not with which program.
Are the reports from the AutoCAD Plant 3D Data Manager or the AutoCAD Plant Report Creator?
Also in this article Tagging Issue you write a lot but don't tell us what you really want.
Please write your posts and add pictures so that we can help you.
Induitively, we don't always understand what is meant, even if we try hard. 😉
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
The reports are in Plant Report Creator.
I was wondering if I could copy settings from the General option into the Project option.
If you select the "Project" check box, all of your preconfigured report templates will be copied to the selected project in the 'ReportFiles' subfolder and will only be available in the selected project.
If you make changes to the report templates in this project, they will only be available for this project.
These are files with the extension * .RCF you can also copy or move these files manually between projects.
Hartmut Eger
Senior Engineer
XING | LinkedIn
