Solved by Jsuffet. Go to Solution.
Still looking...
Is anyone familiar with the Cadworx datafile.tbl location?
The datafile.tbl needs to be in the same folder as the specs as well as the *.dic file. If you are able to get this to work please let me know. I am having the same issue.
Build the specs from scratch, taking best advantage of the benefits of the native system. By the time you get a working conversion properly tweaked and checked, you wouldn't be saving that much time.
Hello
ECE Design now has a tool to Convert newer (>2013) CADWorx specifications to Plant3d.
https://www.ecedesign.com/socketworx/specworx/
Thank you
Jeff
Our company is currently in the process of evaluating switching. We watched the webinar as well and they are doing a demo for us this week with one of our specs. We have probably around 100 specs to convert and this has been one of our major hurdles as to not to switch in the past. We buy the AEC collection so plant is basically free.
I am still using both.
Some clients are requiring Plant 3D.
Some companies site cost for the switch.
Both Cadworx & Plant 3D both have pros/cons.
We purchased the ECE Specworx. Very disappointed. Having to redo much of the conversions and just rewriting others. Comes as is with no support unless you purchase support.
