Control Valve subclass
PJ_Hall
PJ_Hall
Is there a way to create control valve subclasses? For example, can I create a "ball control valve" subclass under the control valve class?
h_eger
Dear @PJ_Hall ,
Technically it is possible but I have never tested it.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
PJ_Hall
Ok. I will give it a try and see if it opens up any new capabilities.
PJ_Hall
Ok. I was able to create subclasses for specific kinds of control valves. But I don't think it really got me anywhere because I can't really attach an actuator to. I can map it to specific 3d valve classes. But the whole process is clumsy. So here is what I propose.
1. Eliminate the control valve class. Valves are valves whether they are control or hand valves. These can easily be mapped to valves in spec.
2. Make actuators an engineering item in the instrumentation class. These are what is actually being communicated with and should be tagged with the instrumentation tag.
3. One should still be able to take a hand valve and convert it to a control valve. But instead of putting it in the now defunct control valve class, it would automatically attach an actuator and attach a specfic tag to each component.
Thoughts?
h_eger
Yes, I have also racked my brains over this control valve a few times.
Please enter this request in the Plant 3D idea station.
Hartmut Eger
Senior Engineer
XING | LinkedIn
