AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Connection between flanges with just one collar
2 REPLIES 2
s.strat
147 Views, 2 Replies
Hi. I am struggling to set up a connection bettween a collared loose plate flange and a slip on. The issue is that when i connect it adds 2 collars and i would only like one. When i have the collared flange and try to add the SO to the conn. i have teh following error message,issue.PNGMicrosoftTeams-image.png
2 REPLIES 2
h_eger
in reply to: s.strat
Dear @s.strat ,
This connection should be configured as an asynchronous connection.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
s.strat
in reply to: h_eger
Could you please be more explicit about it? the connection seems to work for 2 collared lap flanges but when i replace one with SO it does not connect. Thank you.
Technology Administrators
