AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Compass snapping to weird angles
2 REPLIES 2
Khez
175 Views, 2 Replies
Khez
Hi, I'm having a problem in a piping file in P3D 2024 and I have no idea how to solve it
Whenever I try and route a pipe or orient a piping component, in every plane, my compass only snaps to the following angles
80°
250°
270°
345°
Despite my compass snap angle being set to 5 and display angle to 10 and it only happens in that one specific file, I don't know what I might have accidentally changed for it to occur. My model is only a couple of metres away from the drawing's origin point
I tried:
Changing compass' snap angle  and visual to various values
turning off/on again the compass
Activating and deactivating PLANTPIPESLOPE (I never use it anyway)
turning off/on again DYNMODE
Changing from paralel view to perspective/changing viewstyles
closing and reopening the file
Closing and reopening plant 3D
So I'm out of ideas, and needless to say, it makes it impossible to route new pipe
80°
250°
270°
345°
I tried:
Labels (1)
2 REPLIES 2
pmagalhaes789
in reply to: Khez
pmagalhaes789
If it was me, since the issue is isolated to a single file, I would recommend creating a new file, copying the assets over, and deleting the problematic file. Make sure to create a backup first in case anything goes wrong. This can help bypass any hidden settings or corruption that may be causing the issue.
Paulo Magalhaes
www.graitec.com
Paulo Magalhaes
www.graitec.com
Khez
in reply to: Khez
Khez
Dang, I just figured it out!
A little while, since my north wasn't in the right direction compared to reality, I tried going to UNITS then Direction...
And chose a base angle of "North 90" instead of the default "East 0". It didn't seem to have much effect, so I continued on.
little did I know it would mess up Plant's compass as well as the polar snap values
I turned base angle base back to 0 in the units>direction dialog box and it fixed it
