Live Project
I have Modeled the Piping in Entire Project with Line Number Tag as per below Snapshot.
In Isometric Line Number was Coming "Size-Spec-Number"
Test Project
Now I tried with Line Number Tag as per below snapshot in a Test Project
In isometric Line Number is Coming desired format Like "Service-Project Code- Number-Spec-Size"
In Live Project I have Changed the P3dlineTag similar to Test Project But Pipe model Line Number Tag not changed (Showing only Number) and in Isometric Line is not coming as desired.
Only If I Model a New Line then Line Number Tag coming in Pipe model as Test Project and Iso also coming as desired.
Now my question is how can I change the entire Line Number Tag of "Live Project" to similar as "Test Project" as my Isometric Line Number should come as "Service-Project Code- Number-Spec-Size".
There are a couple of ways you can solve the issue.
Refer to either:
1. How to customize the Line Number to match Client Standard in AutoCAD Plant 3D
2. How to create a line number scheme for an isometric drawing in AutoCAD Plant 3D
3. Configuring AutoCAD Plant 3D Isometrics
One of these solutions should fix the issue.
Dear @kumarswapan64 ,
Plant 3D 2022 Project Compare
Command: PLANTREFRESHACQPROPERTY
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Good morning H.EGER,
I wrote last mount about TAG configuration, it´s almost fully solved, almost as i wish, only 1 thing left to solve, i configured program for creating a new layer at the moment of drawing a pipe in 3D. I configured TAG by using 3 parameter, AREA / NUMBER / SERVICE. At the moment of routing a new line pipe program creates a new layer by using the selected SERVICE. The point is that i don´t want the selected SERVICE appears in the new TAG, i only want SERVICE for creating layer purpose. I know it is possible, because a couple of years ago i worked in another engineering office and it was the method that they used.
I attach 3 images for improving my explanaition
