AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Center line in Orthographic view uneditable
2 REPLIES 2
878 Views, 2 Replies
When making an orthographic view from my plant 3d model, a line appears in the middle of the pipe that is uneditable. Usually I am able to hide this line by locating it in the layer properties, but this drawing generates everything on a single layer. Is there another way to remove this?Screenshot (28).png
Labels (4)
2 REPLIES 2
h_eger
Dear @Anonymous ,
in the Layer Properties Manager there is a layer for each view with * _CENTER which can be switched on or off
once with Centerline
once without Centerline
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
in reply to: h_eger
This normally works for most of my drawings, but I'm not sure if the layers got merged somewhere along the line but turning off the center line hides the entire drawing.
