AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
CATALOGUE
3 REPLIES 3
MKK20
537 Views, 3 Replies
CATALOGUE
@diana.yr @jabowabo @h_eger @Anonymous @DGRL
I want to build a catalogue of valve using plantpartconverted custom blog, which I did but whenever if I use it (cat) in other PC the image is not visible though I copy whole drawing with images and cat to that PC (cat, drawing and images are in same folder) which are generated after plantpartconvert.
for ref find attached image
3 REPLIES 3
DGRL
in reply to: MKK20
@MKK20
You should also copy the CatalogSupportFolders
If this was of any help please kudo and/or Accept as Solution
Kind Regards
Vasu27
in reply to: MKK20
@MKK20,
in your machine, where you created the catalog, you will find a folder named 'CatalogSupportFolders' in location 'C:\AutoCAD Plant 3D 20xx Content'. This folder will have subfolders, containing images and drawings. As @DGRL mentioned, you have to copy that entire folder and place in the same location in your other machine too. It will be even better to have the catalog also in the same location as your old machine.
Vasu
MKK20
in reply to: Vasu27
Is there any way to change the default path of blocks image storage by plant catalogue
Technology Administrators
AutoCAD Beta
