AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
CATALOG EDITOR REMOVE SIZE
2 REPLIES 2
schorney
454 Views, 2 Replies
Dear Autodesk,
Can you please add the ability to pick multiple sizes in the catalog editor to Remove size.
Picking each individually is a nightmare!
2 REPLIES 2
h_eger
in reply to: schorney
Dear @schorney ,
as soon as you manage to program a multiselect over several lines in a database, Autodesk will fulfill your wish.
Unfortunately not possible for technical reasons.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
jabowabo
in reply to: h_eger
@h_eger :The editor actually uses a WinForm DataGridView to interface with the database. The DGV control unfortunately does not have the built-in capability to allow the user to check multiple boxes but it can certainly be made to do so with very little work - see screencast for an example. The problem here I think is that Autodesk did not directly develop the Spec Editor application and doesn't seem to have much interest in tweaking it to make it more user friendly.
@schorney : There is already an Idea posted here - it wouldn't hurt to up-vote it.
