AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Cannot create equipment peqx
3 REPLIES 3
766 Views, 3 Replies
I cant get my own peqx zips into Plant 3D
I have been following through "PD1746 - Scripting Components for AutoCAD Plant 3D 2012". My own .py file registered in the CustomScripts folder works fine.
Ive now tried creating the package but cannot get it to show up. Do i have to run a command after restarting P3D?
Ive also tried copying an existing package (from the pump section) and editing only the EquipmentType.xml guid and display name, which also does not show up.
Have i missed a step???
hope you can help,
Wane
3 REPLIES 3
nghiabt04
I have the same issue with you, are you solve that now ?
plantinfo28
Tricky one.
rajendra.prajapat
@Anonymous
 could you please attche your .peqx file here?
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
