Cannot Add Valve Operator to Custom Valve?
I created a 7" valve today in spec editor using two methods, first copying and changing dimensions etc. when that did not work I created a new custom valve from scratch.
Neither of these allowed me to add a valve operator, or actuator.
As soon as I selected the 7" valve in edit operator I got an error message.
It appears to be related to the actual number '7'? Maybe because it's an odd number in the table???
I am not sure but it is crazy, you should be able to create valve sizes of any size.
Has anyone else come across this bug?
Using AutoCAD Plant 2017.
Thanks in advance.
Replies (8)
Hi
did you select 'valvebody' and not 'valve' when creating the valve?
You can assign actuators to 'valvebody' only.
h_eger
Hi @Anonymous,
Is correct what @Anonymous has written.
With 'VALVEBODY' it works.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hi, and thanks for your replies.
I must be missing something. Please see attached images for problems I am facing. I am not sure how I can select the valve body when editing valve handles?
First, I am not sure why size 7 has been placed last when it should be in numeric order?
Second, size 7 does not show up on the size list for default operators?
patpat79
Good day. Maybe you can try adding the Operator in the Catalog interface and not the Spec and see if it would work, many thanks.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Ruffy85
see attached pic. you can define this by creation.
7" is not standard in your class only 6" and 8". so you have to add this by your own.
Thank you everyone for your replies.
I ended up creating a custom part which was much faster, and it is an area covered by 'others', but I did also add the 7" valve to the spec using the method you suggested.
Differentiating between valve and valve body seemed to be the ambiguous point for me, because when you add a valve to a model you are not given the choice between adding only a 'valve body' or a 'valve'.
Now I need to add the 5 1/8 valve, should be much easier.
Ok, I don't want to appear lazy or a nuisance, but I now need to add autoconnectors. I have searched around for the answer.
I have added the RTJ gasket size to the gaskets section, and the matching flanges, but I get error message 'can't find part in current spec' when attempting to route flange or piping from this valve.
What function determines connectors to new custom components?
Ok, I muddled my way through.
Added Gasket fully dimensioned
Added Bolt Setfully dimensioned
Added RTJ Flange,fully dimensioned, then set connections accordingly
Added reducers fully dimensioned
All works fine now.
Something that I have always found a little frustrating with Plant 3D, is you can't add a reducer to enlarge with right click selection, you can only reduce.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
