We have now tried it on a other computer, without any luck.
I will try to decribe what we have done.
First we copied the xml file to the local directory.
Opened then Project setup
Followed the guide given on the web page.
Closing the project setup, a sync window appers, and the window closes.
If I now wait for some minutes, the sync window shows agian and the xml file on the local folder is gone.
If I try to close the project and open it again the xml file is gone or if I refresh the project it's gone.
If I try to I have chected on BIM 360 and the xml file is not there.
We noted that it does not Check inn the project settings, and even if I close the project on my computer when others tries to open the project setup they get a message telling them that I'm not check it in. Strange.
I hope that you can help us with this problem, because now we can't change any thing in the settings
