Can a pipe tag not be mandatory when create the tag?
adria.tormos-virgili
Hello, I'm creating the tags of the pipes of the project, with the pipe tag creator, but I have some pipes that have less properties than the others, (the none insulated ones). If I let the tags without information, the tag doesn't appear well in the properties. It is possible to make some files to not be mandatory when creating the tag?
h_eger
Dear @adria.tormos-virgili ,
No, it is not possible to use different TAG formats.
You can, however, design the annotation differently, once with insulation and once without.
If my reply was helpful, please give a "Kudo" or click the "Accept as Solution" button below (or both).
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
Hi, thanks for your reply.
But I'm not understanding what you mean by design annotations. I can create different tag formats, but I can just select one to use for the designers.
h_eger
for Information only
Hartmut Eger
Senior Engineer
XING | LinkedIn
