AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Bubble tag
3 REPLIES 3
747 Views, 3 Replies
Bubble tag
Dear sir,
I have a problem  with multiline valve/instrument tag. It has to do with Isoconfig.xml, if we change the ForceUpcase="true" the second line tag will come out, but if change ForceUpcase="false", the second line tag dissappear.
 Autocad Plant 3D 2014
Thanks in advance!,
Arief
3 REPLIES 3
jabowabo
Make sure you are using "\P", not "\p" in the Plantdefinecalcproperties script.
in reply to: jabowabo
Yes, I did, as well as I follow the instruction of PDOTEAM article about INSTRUMENT BUBBLE on Isometric
Sorry for early respon, You're right, it should be "/P" not "/p"
Thanks for your help
Technology Administrators
